1 - 10 of 10 Posts
i got a 99. it has a monster pump .93 cross over tube and lines, 200 hp injector, 66 turbo, and edge with attuide, air filter. and im thinking about putting nitrous on it. what kind of shot should be put on it 150,200,300,400. or is this a bad idea. i got main studs in it. and 13mm head studs.
I'd start small and work your way up. What all is done to your head besides studs to support injectables? I'd be looking into o-rings if you don't wanna poop out head gaskets all the time. Other then that I'd spray away!!
either 12s or 14s no? dont think they make a 13
I seen one of my friends blow his stack off and into the back of the bed of his truck hitting his lockup switch too early while spraying nitrous! Big backfire!
1 - 10 of 10 Posts
