1 - 4 of 4 Posts
Here's a real newbie question:
My transfer case seal is leaking.
Until I get it fixed can someone tell me
how to check the fluid level
and if needed , how to add oil?
Rescue Tower
Should be a plug you pull out. There is a top plug to fill and check the level, then there is a bottom plug that you drain the case with. Obviously pull the top one...
Thanks for the info. Ok, so how do I check it? With my pinkie finger?
Do I fill it until it spills out with one of those bottles that you squeeze?
Sorry, I know these are rookie questions but I am learning :)
Yah, just get one of those squeezy bottles, and fill the top hole slowly until fluid just starts to come out of the hole. Then its topped off :thumbsup:
1 - 4 of 4 Posts
