Gauges ar a great first step. I have fuel pressure, exhaust temp and boost on my pillar.
I had 8 pdi fuel pressure at idle, when I started running Crazy Larry I could draw it down to zero, that's also when I upgraded my clutch. That's when I put in my AD pump, but if I was doing it again I'd use a Raptor and a 2 micron filter.
Fuel pressure is the pressue going to your CP3 (injector pump)
Rail pressure is how much fuel pressure going to you injectors, (the OUT side of your Cp3) you don't want to go much over 26,000 pounds.
I'm not sure about the Edge, how much rail pressure it adds, running lotsa rail pressure all the time could harm your injectors. When they go you normally end up with fuel in your crank case.
