We are excited to announce the newest addition to our product lineup, the XDP HD Replacement Battery Cable Sets.
The XDP HD Replacement Battery Cable Sets are designed to restore the function of the charging and starting system in your 1994-2016 Dodge Ram 5.9L/6.7L Cummins. Battery cables that are old, frayed, or failing can cause a lot of problems in your truck. Inferior battery cables can cause poor charging, hard-start, or no-start conditions that can leave you stranded or put excess strain on your electrical system.
The XDP Replacement Cables are constructed from 2/0 (or 00 AWG) wire for optimal conductivity and are made specifically for your application with heavy-duty crimped-on tin-plated copper terminals. Each connection is then sealed with an adhesive-lined shrink wrap to reduce the risk of oxidization from the acidic battery fumes that can shorten cable life. Each set comes ready to install with military-style battery terminals, terminal covers, and wire loom for added protection.
Find out more info here -
