1 - 12 of 12 Posts
2002 Ram 2500
My wipers were sketchy for a while, sometimes working sometimes not, then they failed totally. I replaced the motor and the multiswitch figuring it was one or the other and they would both fail eventually since it is a going on 13+ years old.
With the new motor and switch installed but not connected to the wiper connecting arms I switched the wipers to the low setting. Nothing happened. I rotated the motor shaft slightly and it started working.
Before I installed the wiper arms I tested the motor and switch and everything worked great. Intermittent delay settings, low, high and off and the connecting arm on the motor shaft would return to the stop position when turned off.
I put the arms on to do a final test and unfortunately I put them in the wrong position. When I turned on the wipers they moved to a point where the mechanism was binding and stopped. I quickly turned off the wiper switch and the ignition.
I removed the wiper arms and tried running just the motor again but it would not move. No sound or movement. I rotated the motor shaft about 30 degrees or so and tried again. Nothing. Another 30 degrees several times and still nothing. I checked the 25 amp wiper fuse in the cab and swapped out a known good relay for the wiper relay, still nothing.
So what happened? I can't imagine the motor burned up that quickly. I have had frozen wipers before in the winter and the motor didn't burn up even though the switch was left on for more than 30 seconds. This was on maybe 5 seconds at the most.
Any help would be appreciated. I need to get these wipers running by Friday or I will have to rent a car for a planned trip.
Thanks,
Don
Both parts are new, but one or both could still be bad I suppose. My meter battery is dead so I can't check continuity or voltage at the motor or the switch but will do so as soon as I can.
Thanks for the tips so far.
Don
There is no spoon
Geezer,
Rotate the motor on around some. Look at the FSM pages attached. The CTM is probably not seeing the park sense return from the motor and allowing the rest to start up. The circuit is just lost, so it won't restart. Or the park switch in the motor has fubared. ( edit: snap watch out for the wiper motor relay.... didn't see that till just now.)
GL HTH
Hag
Geezer,
GL HTH
Hag
Hag,
Does the wiper switch need to be on or off when I slowly rotate the motor? Ignition on or off? Battery connected or disconnected?
I rotated the motor shaft clockwise (looking down at the shaft) slowly several full turns with the wiper switch set to low and the ignition on. Nothing happened. It doesn't want to rotate counterclockwise so I didn't try that.
With the wiper switch set to intermittent I can hear the relay in the engine compartment clicking on and off. I also tried rotating it slowly with the switch set to intermittent, but nothing happens to the motor.
What does your comment "watch out for the the wiper motor relay" mean?
Can I check the park sense return switch somehow with a meter on the correct terminal?
Can I check the motor function with a 12v manual input to the right terminal?
FYI, I have no clue what the various terminals are on the connector to the motor to do any checking with a meter or voltage.
There is no spoon
Geezer,
Do you see the attachments that are there? These will help you figure out the wiring. (I am assuming you can see them.)
Good that you hear the "clicking" that would be the relay that you should "watch for."
The clicking tells us that the multifunction switch, is telling the CTM to begin timing. The CTM is timing, and telling the relay to energize.
What we don't know is if the the signal is getting through the park switch back to the multifunction switch and back to the motor.
The schematic makes me think that at some point of motor rotation, terminal 3 (Dark Blue) and terminal 2 (Dark Green) will be continuous. Then 180 degrees from that terminal 2 will connect to the ground (black) wire (no terminal number, is this separate from the connector?) (but notice while they have terminal dots, there are also parts of circles. SO, it could be that terminal 3 is continuous to 2 for about 220 degrees and to ground for the other 140.)
This is where the problem may have come in..... according to the schematic, that wire can be full hot or ground depending on motor position and relay state..... So turning the motor then powering the system could have caused the problem.
Start there, then check for voltage (12v+) at 87 (all the time) and 87a only when the relay is energized.
HTH
Hag
Discussion Starter · #10 · (Edited)
I got my multi-meter working today and started testing all the leads going in to the motor. Several of the terminals showed 12 volts so I knew power was at the motor. I found that the black ground line that is attached to the spade lug on the motor housing has an intermittent break in continuity somewhere on the engine side of the cowling. I checked from the connector and through the insulation back about 10 inches with no ground there. I have to drive 8 miles of washboard and rocks every day which could explain why it was intermittent previously, and then finally gave up completely.
When I added a new ground wire straight off the lug on the motor, bypassing the black wire coming in, and attached it to a good body metal ground, everything worked correctly. Will that be OK or should I run a longer wire to some other ground spot? Does that black wire do something besides completing the ground circuits in the motor?
The original switch is fine, so I put that back in. The original motor is really slow and sounds pretty tired so I kept the new motor installed.
Let me know if I need to replace that black wire all the way to the source ( I am assuming it is somewhere on the engine side fuse / relay box) or if my ground wire replacement to the frame will be OK.
Thanks for all the tips from everyone. Not having wipers was getting really annoying, not to mention dangerous.
If it's working, I wouldn't worry about it, however I would tie it in with the ground you made..... Depending on where it lost ground you might have other things not working because of it..... By back feeding ground they should work again.
That being said the best fix is to replace it to the point that it has a good connection again.
There is no spoon
Geezer,
Off road is right. That ground just goes to G100 which is a common ground for a bunch of stuff. It is on the driver's side under/near the battery.
You can ground it anywhere.
Glad you found it.
Hag
1 - 12 of 12 Posts
