I just replaced all the internals in my whole 47re with the exception of the shafts and gears, all the clutches ect. were replaced with the BD "stage 3" heavy duty kit. the valve body was replaced with the BD Valve body, and my converter was replaced with "Diesel Performance Converters" super single converter. I had a local shop do all the work. But i took the trans out and put it back in. once the whole trans was bolted up and filled i took it for a spin, the 2-3 shift was real hard, so i adjusted the TV cable up by the throttle on the clean side of the engine. now the trans shift awesome from 1-2 and 2-3, it shifts around 2,000 rpm. the 3-4 shift takes a little but it does shift with out and difficulty, the problem I am having is that once i'm in 4th which correct me if i'm wrong is known as Over Drive. Truck will tack up as high as red line and will not go past 60-65 mph. It sounds like the truck still has one more gear too go, but it is already in 4th as i have counted every shift. I have not checked any sensors only because I cant see a sensor causing this problem. Is it the valve body? Am i missing something while adjusting the tv cable? i'm at a loss. is it the converter? i have no clue how to feel if the converter is locking or not locking. It might be a little hard understanding what im saying but i have no clue how else to explain it.
In simpler terms the truck shifts fine from 1-3 but the 3-4 shift takes a little long and once in 4th gear my truck feels like it im driving a combine very slow and high rpms, the truck use to top out at 95mph with the rpms low.
any help would be greatly appreciated, my only move after this is too put the truck in the shop and which Christmas coming up i don't need that bill :banghead:
