Banned
I have a 97 12v in a 92 f250 so I'm not new everything. My cousin bought a 92 d250 for 900$ with 130k miles as runs and drives pretty. Good. Where can I find the kit to swap a p-pump on it and then put an I/c with bigger pipes with and an hx35
Basically make it into a p-pump motor
Why do you want to convert it?
You can make 350-400hp to the ground without too much trouble.
Sent using AutoGuide
Banned
What would it take to make that kind of hp? I turned the pump up a little bit already but was thinking if we swapped it over to a p-pump we could gain more hp easier
So what would it take to make 300-350 hp?
Or point me to a thread
325 hp excluding any possible transmission work would take this
5x12 injectors.
Grind the fuel pin
Higher volume lift pump.
4" exhaust is a good idea
He351cw
Turn the fuel screw in (free)
Gauges.
That's what I would do.
