Just so you know you're in the 12v forum. not the 24v. you'll have much better luck askign in the 98.5-02 24v section.
In the mean time I would suggest a three gauge set Pyro, fuel pressure, probably trans temp or boost. from my limited 24v knowledge i know the fuel pressure gauge is a must to make sure you keep your IP alive. but like I said repost his question in the correct forum and you'll get much better responses (also try the search function, some members get all bent out of shape if the same question gets asked a ton)
congrats on the truck
