Your head gasket should be fine just let it warm up completely before you lay on it hard.
VERY important.Your head gasket should be fine just let it warm up completely before you lay on it hard.
This I understand working in the gas field.3600 cats are bad about gaulding pistons if you load them before the oil gets to operating temp.VERY important.
that has nothing to do with cold oil.....This I understand working in the gas field.3600 cats are bad about gaulding pistons if you load them before the oil gets to operating temp.
The Edge has cold engine protection . . . can anyone confirm Smarty doesn't?that has nothing to do with cold oil.....
He is referring to timing table changes due to a cold engine. The timing tables are adjusted strictly for emissions.
Its not hard at all.....The Edge has cold engine protection . . . can anyone confirm Smarty doesn't?
You wouldn't think it'd that hard to write in the files till operating temps were reached.
Please educate me on emmissions timming tables. This I am wanderring about since I am deleted.I'm really interested about this.I understand cylinder pressure lifts heads and I understand that advancing timing can subsantualy raise cylinder pressure. what I dont get is how 100 degrees plays such a large roll in all of this?that has nothing to do with cold oil.....
So my question is, why are we assuming the S-67 doesn't do it already?Its not hard at all.....
I took every bit of that BS out of my LBZ duramax!
Its like driving a mechanical engine with electronic provisions. In other words the driver has to be smarter than the engine!!
Cold cylinders = white smoke = unburnt fuel from a common rail.Please educate me on emmissions timming tables. This I am wanderring about since I am deleted.I'm really interested about this.I understand cylinder pressure lifts heads and I understand that advancing timing can subsantualy raise cylinder pressure. what I dont get is how 100 degrees plays such a large roll in all of this?
Oh shoot,So my question is, why are we assuming the S-67 doesn't do it already?
I don't romp on my truck when it's cold . . . but this thread is taking for granted the Catcher software isn't doing it.
Whatever compressor configuration your running such as Arial...... IS the lubricator and oiler using the engines engine oil, or is it pumping its own oil from the compressors crank case. I have personally seen the desgin where the lubricator pump for the compressor pistons was utilizing engine oil from the engine and being returned back to the engine.....Hannover(now exterran) packages specifically.when talking about cat engines I refer strictly to 3500 and 3600 gas engines.On these engines in the adem3 configuration the ecm does monitor oil temps.
...........Im not talking about timing tables.LETME RE WORD MY QUESTIONS.Does the smarty not eleminate the timing table adjustments in the ecm for the egr when running the me software?
Ive asked this before and all I get told basically is shut the F up, you know NOTHING, how dare you question smarty
Now my cold engine question (and i'm not disagreeing just proding for info and im not a dumba$$ so I dont need laymans terms)How does low cumbustion temp and lower cumbustion efficency relate to higher cylinder pressure?
It doesnt, but the adjustments made to timimng do in conjunction with MORE fuel :confused013:
I don't work for any compressor company.... Although I've rebuilt a few 4 throw Arials in my day.:thumbsup:?I guessnthese newer comon rails have more gasser features like a diferent timming table for a cold engine?
And just exactly which compressor company are you workin for there catdiezel?
