1 - 20 of 45 Posts
So, I got my new (reman factory overstock) Holset HX40 today, and since I'm like a lil kid on Christmas Day when I comes to truck parts, naturally I started playing with it.
So of course the second thing I did after giving it a good once over to make sure everything felt tight, was to rip that doggone silencer ring out, because I'm 25 and I still think loud turbos are cool. :rof
This is what I found...
Before:
After:
It looks like someone welded shut the space that i think should be there!! This is the first time I've been up close and personal with a true blue HX40, but, the pictures I've seen don't look anything like this once the ring is gone.
Somebody please tell me WTF is going on here?
Discussion Starter · #2 ·
Bump for hump day.
I emailed them and asked for an exchange, still waiting for a response. Hopefully they do.
But if not, what are my options for saving this turbo. Other then this crap, she looks outstanding. I want to use it badly. New compressor housing?? If so, where do I get one??
Any other ideas? And more so, will this negitively affect turbo? I would assume so.
Are you sure that is a genuine Holset? It looks like all the machined surfaces were shot peened after machining. Where did you get it?
Off of EBay. BUT, it's not one of those stupid lil speed shop things that have the Knock off looking turbos. This one has all the tags, serial numbers, 16 in side of the flange, 7 & 12 blade, hell, it even has the arrows on the center section for the oil flow. It's definitely not one of those little $300 dollar turbos.
I'm going to call Holset this afternoon and have them run the #s for me and see what I get back.
You can buy nike shoes with the size tags and logos on them from china
AimPoint red dots with correct markings
They copy things exactly
Discussion Starter · #9 ·
True.
I'm still going to call Holset and run the numbers, at least if they tell me it's a fake, they can get them off the market I guess. I hope this isn't the case. Either way, I'm going to raise hell until this is fixed.
Hope it all works out for you! It sucks getting something new in the mail and not being able to use it.
Discussion Starter · #11 ·
Tell me about it, good thing I took the silencer ring out or I would have never known...
Discussion Starter · #13 ·
Will do. I just talked to my local Cummins dealer, AND my my diesel shop, and neither one have heard of this ever happening.
I will get to the bottom of this.
Discussion Starter · #15 ·
$750 + shipping.
Discussion Starter · #17 ·
Assuming I get screwed over on this and get stuck with the turbo I have, could I just put the silencer ring back in and run it? Other than this, it feels tight. Zero shaft play in any direction, no binding on the blades, I can't find anything else wrong with it other then some jack wad welding those gaps shut. I'm not even sure what those spaces are for???
I wouldn't run it. The welding process could have warped the metal. Also the weld looks like garbage it might crack once you get that thing nice and hot.
I wouldn't take the chance return that thing and get what you payed for.
Discussion Starter · #20 ·
Why would someone do that??
1 - 20 of 45 Posts
