One name is all you need to know.....Isspro. (JMO). I'm running the EV black face Isspro gauges. The pyro, tranny temp and mechanical boost are up in the Autometer 3 pod A-piller w/ spreaker pod. The mechanical fuel pressure is in an Autometer steering column pod. I did NOT use a fuel issolater. I ran a 1/8" tube from the IP inlet thru the firewall to the gauge. I did put the 1/8" tubing inside 1/4" tubing, heat-shrinked it to the fittings on the gauge and put a petcock type valve at the IP; all in the name of protection.
EDIT: I don' have any pitures of the Isspro's mounted. The pic's on MyTruckPofile are the old banks gauges. I can take some and post them tonight.
