So Im replacing a damaged driver's side front fender on my 08'. I don't like the review on the aftermarket fenders saying their thin and dent easy.
I found a used OEM gloss black in great shape (with the Cummins badge still lol)on ebay for ~200 shipped. Is there any reason I can sand that one down, prime, and paint it just like I would an aftermarket pre-primed?
Discussion Starter #2 (Edited)
RockAuto has the Mopar OEM fender for $240, I could do that.
I found a few wrong color OEMs I could pick up real cheap on CL too... LMK your thoughts on the color change.
What is the question? Used OE fender or new OE or re-pop fender, they all take paint the same.
You might get a slight color difference (likely) with that red metallic if it's the truck in your avatar.
However, it's not horribly time consuming to blend it into the door.
Reactions: s10010001
Sorry it was clear. It was new 3rd party e coated fender vs oem pull from a grey truck.
I ended up getting tie oem fender. I figured a perfect fit and OEM gauge steel was more important than my time sanding.
^ ?? Ok, I would go OE used vs re-pop as well.
Whats a re-pop? like fixing my damaged fender?
I ended up getting an OEM Mopar fender off another 2008 truck, wrong color but OEM Mopar. (vs a 3rt party not Mopar new fender ready to paint)
Re-pop is an aftermarket piece. Old auto body slang I suppose.
