hey guys new to the forum:party018:...long story short i got a 93 d350 2wd with an ugly utility bed for 900 bucks guy said the trans was blown and pumping fluid out faster than it could retain it, well that was a lie i got it back to my house and found that the trans lines rubbed together and now leaks fluid pretty good only while running lol, i havent dropped the pan yet or anything just put a gallon of dex/merc to see where the leak was comming from.the truck moves prefectly fine did 50 down the road just leaks fluid, when first started right now it takes a minute or so for it to start moving as it just revs in gear..im assuming it needs to build enough pressure to move?. does this sound like disaster comming or am i did i just luck out? im dropping the pan tomorrow and changing the fluid filter and the line.. speaking of the lines where can i get one and whats the fitting size to the tranny .. all help is much appreciated
Number 1 check the fluid when tran's is in Netural
Quit driving it until you fix the leaks!!!
