Just installed new Borgeson Pump and Gearbox. Want to flush. Have both return lines (from gearbox and hydroboost) stuck in a bottle. Plugged off pump return ports. Have completely removed tie-rod and drag link, since I'm waiting for my new T-system to arrive, so there is no load on the gearbox. Filled pump with Amsoil fluid, started truck, rotate steering stop to stop multiple time. NO noise from anything, and NO activity from pump. Fluid level is not changing. It's not even trying to pump. Does the gearbox need a load like having the steering system all connected up? Does a new pump need some kind of priming? I'm a bit befuddled, but I think it's something very simple, hoping someone can comment? Thanks so much!
BTW, I put a new seal kit in the vacuum pump, and verified vacuum is being produced, so I know the thing is spinning! And I did not forget to include the coupler that enables the vacuum pump shaft to drive the PS pump! It all went together nice and smooth. Truck is 2000 2500 4x4
