New bats but engine turns over very slowly at 60 degrees out temp just about started.
What could be the problem
Starter motor bad if cables in good shape.
1999 so cables?? The primary look fine but the secondary??????? Is there any test to confirm a poor ground
Does anyone sell a kit or best to make my own
thanks
If the batteries are charged perfect (not all new batteries are good) then its either a dragging starter or loose or corroded cables. There's nothing else...
Test with voltage loss test or resistance test. Clean all connections for perfect metal to metal connections. Check cables for corrosion and swelling.
