1 - 13 of 13 Posts
Just got a used Edge Comp with appropriate wiring harness. Where can I find instructions on installing it? I found one set on the net, but it was for a TST & included some kind of plate & elbow?
Discussion Starter · #3 · (Edited)
Thanks!
What is the "90° Brass Fitting"? Wanna make sure I go get the right item to replace what was in the original kit since all I have are the box and wiring harness.
Mine didn't. If you need to, you can just plug the wastegate if you have an HX.
Discussion Starter · #9 ·
Sounds good!
Does tapping into the injector pump wire mean that this box will overwork my vp?
You're going to want to make sure and have some sort of aftermarket lift pump to supply the VP. Otherwise you will more than likely kill the lift pump AND VP, not cheap.
i bought mine used too.... from this guy^^^^^^^ by the way i love my comp and have had no problems with it.
1 - 13 of 13 Posts
