Looking for suggestions on reducing the smoke output on my truck. Currently, on my '03, I am running a
Smarty S06 loaded with TNT software, DDP 90hp injectors, ED 63/68-14, and stock CP3 with an Arson kit.
I did the injectors a couple years ago and thats when things started getting really smokey on me. Since
installing the turbo a few months ago, smoke output has been reduced some under boost, but from no, to low
boost, it is still pretty thick. Like zero visability behind me thick.
I have played with the smarty settings and can get it reduced some, but no where near to what I would
like to see, or not see. Is UDC tuning going to have to be my next step? Can UDC greatly reduce my smoking
issue?
I do not believe there are any boost leaks in the system, though I have not ever pressure tested it. I'm
not having any problems building or holding boost. Rail pressures appear to be working just fine also, although
I have nothing to compare it to. EGT's have been great since the new turbo install. I have not seen it go over
1300 deg since the install, and have pushed it hard more than a few times, loaded and empty.
So is there hope? Or do I need to learn to live with it? Smaller or different injectors maybe?
issue?
