Need Some Tips
813 Views 2 Replies 2 Participants Last post by  M K
I ordered a new grill & driver side headlight/turnsignal assembly for my truck , the old grill has 2 mounting tabs broken & the old headlight has the bottom adjustment broken , the turn signal has some cracked plastic . How difficult is it to change these parts out & is there any tips out there to help make this replacement easy ? I also have a bug deflector on the old grill & it is attached with 2 sided tape , what tape should I get so I can put the bug deflector back on?
1 - 3 of 3 Posts
Taking off and putting on your new parts should be pretty straight forward, just make sure you know where your hardware goes, as for the remount of the bugshield, 3M red double sided tape is the best ive ever found. Good luck!
mounting the headlight assembly is not as straight forward as I was told , I must be the first person to replace the headlight assembly , turn signal & mounting bucket because no one else had a clue on how to do it !!!!!
1 - 3 of 3 Posts
