1 - 4 of 4 Posts
Okay im pretty positive my VP is done. It throws P done, P PCU, and a couple number codes if i havent run it in a while. It cranks a lot before it starts unless i park with the nose downhill. I just put in a new fuel pump and the check valve/backflow valve(?) was replaced in during summer. If the tank is full it starts right up usually but once the tank starts emptying it gets worse and worse. I just wanted to make sure this problem is the VP because i dont want to drop over a grand on parts if they won,t fix the problem. Thanks for the input.
· Got P7100?
Get a fuel pressure gauge now!!!
Also check for fuel/air leaks in the fuel system, specifically the return line on the back of the head.
1 - 4 of 4 Posts
