I got a 92 d350. I need a whole new throttle line. Was wondering if a 94 5.9 Cummings throttle line would fit it
I highly doubt it would be a direct fit. Most likely the connection to the throttle pedal will be totally different, as well as the clip for where it passes through the firewall, and then the cable may be too long/short to mate up with the throttle lever on the IP.
Check out car-part.com they link 1000's of junkyards all over north america....might be able to find what you need?
Maybe one from a gas 1st Gen would come close.
Probably a closer fit, I believe due to the location of the throttle body on a gas motor it is going to be short of the throttle lever on the IP....most likely.
