there should be pre-drilled holes on the outside of the adapters between each wheel stud, take a short socket and stick it on the bolt, take your ratchet extention and slide it threw the holes and press it in the socket. u can have sumone in the cab to hold the brake peddle down or just take a long pipe or pry bar and wedge it between the wheel studs and the ground so that the hub dont spin while your trying to break the bolts loose....hope this helps.
