My Bother In Law has a 1st gen 2wd dually and need some help on aftermarket performance and body upgrades in southern Oklahoma or Northern Texas area. Thanks
1ST GEN
Which year 1st gen???
It makes a differnce on what to recommend.
Is he wanting more towing power or playing power??
I will get yall some more details from him and go from there.. Thanks
1993 and wants more power but yet towin capabilitys also
1ST GEN
Throwing towing into the mix makes the mods he can do limited.
Does he have a boost gage or a pryometer installed????
Those are the first two items he will need. We need to know the current state of fueling to the engine.
A couple of items he can do if he doesn't have gages yet.
A full turbo back 4" exhaust is a good upgrade. The stock 3" system is restrictive. Just that addition will drop EGT's 100 degrees. It doesn't matter if he runs a muffler or not.
The stock 90 degree air horn on top of the engine is another restrictive item that needs to go. He has two options there. Eather a set of cool tubes or a 2nd gen 24 valve air horn. Eather one will provide more air into the engine. I have dynoed with both setups. They both came in at the same HP and torque readings. The 24 valve setup would be cheaper. Here is a pic of the one I have on my truck.
Here is a pic showing the inside of a stock air horn and a 24 valve air horn. Guess which is the 1st gen air horn. :D
