Ok so im about 5 hours from the house, changed my oil yesterday! Now I stop to eat and I got a ton of oil on the undercarrige of my truck, its coming out of the cranks case tube, what's causing this? I put 2 1/2 gallons of oil in it which is what I use every time...help please.....can I just add oil and make it home?
SuperModerator
These Trucks need 3 gal of Oil for an OC, So you are always 2 quarts low, Not good for the Engine.
Check the Oil level, Check if it smells like Diesel.
If it is over filled and smells like Diesel, you have an Injector problem... Do not drive it at all....
If its low and No Diesel smell, add some oil and go from there...
Blowing out the tube maybe a sign of bad rings from running with out a proper amount of Oil.
:agree2: takes 3 gallons total capacity.. and YES smell oil if diesel smell tow to closest shop for repairs or back home.... sounds like u have a mechanical problem though. dont think the low oil level caused this one... :thumbsup:
Sounds like an injector that stuck open.:banghead:
Day der is the problem, burnt 1/4 tank of diesel in 3 miles! Got it at Owens diesel in vicksburg ms, anyone know of them? Got my bro in law coming from Texas to get us
Hide your cats!
could be the #4 injector line came loose. check stickeys on powertrain threads! the injector line comes loose and does just that dumpes fuel all over the undercarriage
