I need the part number for the wix fuel filter that doesn't have the water sensor in the bottom just a simple drain valve.
I found it here once but can't find it now.
Thanks!
Super Moderator
Here is the Fleetguard part no. FS1221 your parts store should be able to cross it over to a wix.
Super Moderator
The FS1232 uses the factory screw in drain, the FS1221 has the drain with a plastic knob you turn to drain. They both have M16X1.5-6H threads the FS1221 is about 2.5 inches longer. There as about 20 fuel/water separator filters that have the same threads anywhere from 3.32 long to 8.61 long.
