1 - 14 of 14 Posts
Hi all. We picked up a 5th wheel toy hauler (GVWR 12.5k) and we love it. The problem is my truck struggles (or seems to) on hills. Granted, once I learned how to tow with a diesel keeping my boost up, it did alot better. My current mods are below, and all I'm really looking to do is not be a dog on longer hills. It does ok on the highway but would like a little more power.
I was thinking to actually install (yea I know) the 4" exhaust in my garage and add a set of RV 275s and I should be ok... will I? I know a fueling box would be great but I can't afford a new turbo right now so I'm looking for the best bang for the buck. ANY suggestions you guys could offer would be very much appreciated.
Thanks much, Mike.
For towing I would say that the Edge W/ Attitude is going to be your best bet... great addition and comes with all the guages that you will need! just my .02
thanks, I already have the VA timing box (65HP) - is the Edge with attitude just timing with the guage pod?
Go for Broke
Edge is Fuel and timing
Check my sig I pull my 7000lb trailer up 7% grade 6th gear 60mph edge comp set on 3.3 run at 1200 degree on pyro 30lb boost.:thumbsup
1200 is the exaust temp you dont wanna go over 1250 too hott 30lb boost is the turbo pressure
Go for Broke
you can go well over 1200 deg., but just don't keep it there for more then a few seconds :thumbsup
i tow heavy dump trailers all the time i do just fine with the adrenaline on 3. i am installing new 50hp sticks i will see how that does
Buy the adrenaline and you can set it where it dont go over 1250 degrees
Discussion Starter · #12 ·
Thanks guys. dmbowhunter, how heavy are your loads and what are your etgs?? How's the acceleration? Are you running the stock turbo?
Thanks.
depends. around 10-12,000 lbs on level 3 stock turbo 1150 ish acceleration is alot better then stock. i am hoping to get a bigger turbo and crank the box up a little more. gets up and goes unloaded.
Discussion Starter · #14 ·
Man, kinda makes me wonder if I have a problem with my truck. I runs good and I get about 21 on the highway.. don't know. Maybe just needs more power.
1 - 14 of 14 Posts
