You can add a leveling kit but you may run into problems with bump steer. You may also need to get longer control arms beins that as you add lift it draws your tires back. Anything over 5-6 inches of lift up front you should be looking at long arms. Your front drive shaft should be ok up to ~7 inches of lift.
