1 - 1 of 1 Posts
Using a '92 5.9 from a W-250 and putting it in a '78 F-250 Lariat 4X4. Going to use it as just a cruiser so I am going to try to use the Dodge auto trans. I swapped the factory exhaust manifold to another style that I see all the Ford conversions do so I could clear the Ford A/C housing. Issues so far 1. Had to remove a tranny oil cooler 2. How the hell do I get the intercooler tube around the motor mount and the A/C compressor? 3. Going to have to loose the tranny fill tube for the exhaust pipe. Wondering if I turn the manifold downside up will help or if I could get by with the factory manifold set up. I thought I could cheat and did not try to fit it in the pickup before the manifold swap. Has anyone done a swap an used the 518/46 rh trans? I plan to use my Ford 205 with an Advance Adapter. Anyone have any helpful advise?
Thanks!
1 - 1 of 1 Posts
