I am in the market for 4 different injectors for my 2004. Last year after buying the truck at a non-Dodge dealer the truck had a no-start issue. The shop this dealer took the truck to put 5 injectors in it from Napa, one injector had already been replaced by Dodge right before I got the truck. As predicted 1 by 1 the Napa injectors are failing. I had Dodge put one injector in at a $1200 price tag. Hence why I am in the market for 4 different injectors.
I have looked online and Accurate Diesel in Michigan seems to be best the best price around me at $235/ piece plus core. Is this a good price? Has anyone used Accurate Diesel before?
Thanks in advance for any responses/ help.
try throughbred diesel in lexington ky Sponsored Listings
your already complaining poor quality, so finding the best price most likely isnt the answer. Maybe you should have asked who makes the best injector, then search the price of those listed. I use Exergy Performance but they arent the cheapest but might be the best.
The only truly balanced injectors are DDP (dynomite diesel) you get what you pay for they actuality will balance a set for you. several sizes available I put the 50hp+ in a month ago nice! Dodge tried twice they use junk!
If you need to you can talk to the guy that does the setup.
NO I don't work for them read TDR
· One part at a time
If he is just wanting stock injectors it doesn't matter where he gets them as long as they're new Bosch injectors with new stock nozzles they will be the same. The only thing being balanced by DDP is the honing done to the nozzles for added hp, and they are not the only ones who truly do that.
