Motor has no top end power. Lower end is fine. Have replaced injector pump, lift pump, computer. Turbo doesn't sound like its spooling up correctly and hear what sounds like vacuum leak or air leak under dash when turbo is under load. Any suggestions or ideas?
Thanks for your help
Look for the boots on intercooler tubes for loosness, or split.
Reactions: Drook
check the exhaust manifold for any soot residue, if there is some then you have a crack.
