I installed a smoke switch a month ago. I tapped the 2 appropriate wires on the factory map harness and ran then to a toggle with a 10ohm resistor in line.
The switch works like you wouldnt belive. My rig smokes like a pro sled puller when i get on it since installing the swiitch.
About two weeks ago i turned the toggle swith off for the first time and I got a CEL and limp mode instantly. I got it home and disconnected the batteries and pulled the PCM fuse for about 3 hrs to try and clear the codes .
That didnt work. So I drove the truck in limp for about 4 days. In town and on the highway and that didnt fix it. So i took the truck to Autozone to get them to clear the codes. All the codes cleared except the one for the MAP sensor, I cant remember the number. We tried a few times but every time i started the CEL would come right back on. We did this with the switch off. So then i turned the switch on and had the guy clear the codes and the CEL stayed off and the truck came out of limp mode. So now I have to run with my smoke switch on all the time or else Ill get limp mode.
Does anyone have any ideas why.
Also Since doing this mod my engine fan seems to always be on and thats annoying also. My buddie did the same mod to his 03 and his engine fan always seems to be on now too.
Does the Map sensor have anything to do with the fan coming on??
