1 - 20 of 25 Posts
last night i took my truck out to the track for the first time. my et's 14.3 @ 104mph. the truck is derating when i first launch (a stutter). when i hot brake it starts to spool up and then derates to 2000 rpm. what do i need to do?
do you have your edge limits shut off so it doesn't defuel or anything so you can run as hard as you want. Those are still some good times
yes i have all edge limits shut down. was told that it is the chrysler software taking over and i need to install a smarty software? i also am running 35" tires. i'm baffled?
how ar e you leaving? What boost I take it your 2wd or 4wd?
4wd, when the truck derates it has hit 20 psi then backs to 5 psi.
what does a bd rad do??? what is a bd rad?? (radiator)
A BD RAD eliminates torque managment. What this allows you to do is power brake and build boost with out defueling.
Racer
Anti
Defueler
yeah and with a speed of 104 while defueling hold on because your gona knock atleast a second off your ET's!
Discussion Starter · #12 ·
thanx for the info. do you think it would help to run smaller tires?
I must say those are some good time for a suttering truck.
Good luck with it.
Let us know what your times are when you figure out the problem.
Discussion Starter · #15 ·
where do would i look for a bd rad? how much $$ ? thanx for the info again!!
Discussion Starter · #16 ·
installed water/meth today, smarty friday, race friday night
Discussion Starter · #17 ·
ran a 13.7 @ 101mph! launch is great but feels like the trucks top end is not what it was? any help?? egt and intake pressure is lower. i have done an air to air test; ok. i have also played with the water settings, turned temps way up???
the smarty kills the top end thats why i hate it but it removes the tourqe management to about 80 percent so its a win loss the bd rad just removes the tq management without the loss of topend
1 - 20 of 25 Posts
