Well, I just finished replacing the p/s pump and gear. I've got everything back together and completed the procedure the service manual says for initial operation (which I assume is for getting the air out). Took the truck for a test drive and the steering seems harder than before and the pump whines pretty good while turning at low rpms. Also, when the truck is parked at idle, I can only turn the wheel very little and it will not go any further. The hydraboost also seems to be getting real hot. Did I get a bum pump or is there still air in the system? Please help!
LJ
LJ
