i have a 1990 dodge LE 250 ram cummins diesel an i had seen wher guys put a steering colum pod on these trucks, so i ordered one from jegs an it came 2day but it doesnt seem to fit, they said order it for a 1994-01 dodge ram cummins an it would fit on the first gens. any suggestions or help is appr
You could just trim it to fit.
1ST GEN MODERATOR
That gage pod only works on the tilt column trucks. If your is a straight column the pod is way to big to fit.
Iv'e seen this somewhere??
First Generation Moderator
Yeah........
It fits ONLY the first genneration trucks, WITH the tilt column and WITH the square/boxed column....NOT the 1990 tilts that are round. No go there. I think you'd be looking at 1991.5-up with the tilt.
Sounds like you didn't get all the information on that from the start.
It fits ONLY the first genneration trucks, WITH the tilt column and WITH the square/boxed column. I think you'd be looking at 1991.5-up with the tilt.
I seem to have a mis-mash truck, a composite of at least 2 others. Do all the (stock) 91.5's and beyond have tilt?
1ST GEN MODERATOR
Tilt was standard on the LE models. On the base line trucks it was a option. The LE's were the top of the line trucks.
My 90 LE has tilt. But, it is a small round column. The pods I've seen pictured won't fit. But, there are options.
