Heck I used plain old gasoline and a acid brush!
Clean as a whistle!
Clean as a whistle!
I had the same thing happen to me but it was my boost fooler. Same code and actions. James replaced my boost fooler and all was perfect. Just a thougt since nothing else is working for you. Good luck.i went to the dealership and they said it was the map sensor so i got a new one and put it in and now my truck is worse. the lightning bolt comes on right after startup and whe i get over 2000rpms the truck bucks and romps and wont do sh$t. any ideas?
Sounds like your truck is trying to regen. White smoke is almost always the result of regen. Have you checked your sims to make sure you didn't get water in them? Or to make sure they are still intact? This is the most likely cause of an attempted regen.i have this lightning bolt problemo along with a ton of blue/white smoke. i got it after drivin through a terrential downpour last saturday night. gonna try the brakleen on the map. if i get the code free xrt will that fix it.
