Need alittle help
678 Views 7 Replies 4 Participants Last post by  Chase691
I got 02 cummins 100hp in edge comp hot an a he351cw an i feel like my truck is lacking power for some reason just dont seem to pull well i have 12v power at pump tap everything is hooked up idk any ideas
Hows boost pressure compared to before, hows FP at WOT, any smoke?
I hit like 40lbs of boost it smokes just not as much as i thought it would fp dont get below 15
Pump taps are finnicky. Is there a large difference between edge and edge off.
What's your temp like there? Don't forget smoke difference between summer and winter.
When it's cold here, I smoke less and not as thick as I do through summer.
The highest egt temp i get is 1200degrees but our average outside temp is around 60degrees
It will help get the best answers possible if you put all your mods in your sig.
It wont let me write in my sig so. But all i have is 100hp injectors an edge comp with he351cw turbo truck doesnt seem to have alot of power i can tell by the amount of smoke idk what else to do i solder the wires together for the pump tap what else can it be my vp44 is fine brand new 8 months ago
