Well I found a crack in my buddies transfer case. any ideas where he could find a new one? I checked with dodge and jasper and both are extremely high. Didnt know if there was anywhere else that i could check
How bad is the crack? Can it be tig welded?
Have you thought of repairing it. Cracked the 205 T case on my chevy when i was a kid and we brazied it worked just fine. If its just a crack take it to a good fab shop or off road shop and they should be able to tig weld it back together for you
I repair transfer cases, transmission cases, bellhousings, ect everyday at work... Even it has a hole in it the size of baseball I can repair it so you can't even tell that it was ever broken.
Have a reputable welding shop TIG weld it for you, it will be as good as new:thumbsup:
Discussion Starter #8
thanks for all the info...im going to check into it being welded
