Status
Not open for further replies.
1 - 14 of 14 Posts
Hey guys I'm looking for a 35" E rated tire. Needs to be an all terrain. I'm putting them on my factory 17" wheels on my 2010. I have looked at every tire I can think of. I just don't know. I need advice. It has to be a E rated tire I won't run a D. Pics would be great if you have them too! Thanks guys.
Firestone/Bridgestone 315-70-17 AT's/Mt's. However,someone has posted that the AT's are backordered.
nitto terragrapplers
there great
How is the wear on the Terra's? I really don't mean to hijack this thread but I've heard mixed things on them and I'm kind of in the same boat, I will be needing some tires pretty soon and I was thinking about trying those.
the terras are wearing great. looks like new after 5000
wearing nice and even too
think i had it set for 40psi in front and 35psi rear for empty truck
rated for 3600lbs at 80psi if u need that much
I liked these because they are kinda between a A/T and a M/T
quiet tires
Fuzion XTi
After upgrading to a 2010 you may not have that much left over for tires.
At their price point this new AT tire from Fuzion is E rated in a 315 70 17 & looks like it has a decent tread pattern. If you plan to haul heavy the load rating looks a little low to me. $191 / tire from Tire Rack
Fuzion XTi
No doubt the USA made Firestones & Bridgestones are better tires but they will cost you more to buy & many are on back order. Load Range E 35" tall tires for 17" rims are not that plentiful. If you need tires pronto this Fuzion XTi might be worth a shot.
Discussion Starter #10
Hey thanks guys. I have looked at the Firestone and I like the tread pattern but I have never seen them on a truck... Any pics of the Firestones on a truck? I don't really like the superswamper AT's. I have run numerous sets of Nitto Terra Grapplers and they always wear well. I just didn't see them in a 35. Finding a 35 in a E rated tire for a 17" wheel is hard. I wanted the 35" Toyo AT's but they are only a D. So far I like the look of the Firestone AT's. The new General Grabber AT's, The Kuhmo Venture KL78. It looks good on a 20" wheel but I'm not sure on a 17. Don't really like the duratracks. Keep then coming guys thanks!!
nittos come in a LT325/70-17 which is a 35 inch . with a load of 3300 at 50psi. Iam thinking of getting a set .
Bridgestone makes the 35 in load range E. They are not a bad tire. Firestone are cheap and you get what you pay for. Kumho i dont think they make the 35 in load range E. Duratrac not a E. BF not a E. So your only option is the bridgestone or firestone. i would go with the bridgestone but rotate regularly.
Firestone and Bridgestone truck tires in the 315 size share the same carcass. They have the same load and speed rating. Each has a unique tread pattern. Like everything,prices are up.
1 - 14 of 14 Posts
Status
