i saw this tapped hole next to my intake manifold and was curious if i could run my boost gauge to it? or does anyone knw what it is?
Pull it and see what comes out cant be to bad what ever it is :thumbsup
On my 03 my APPS is mounted in that spot in front of the intake horn. Could be they still use the same plate and that's what it's for. You could drill it and take your boost pressure from there, but you would need to pull the intake horn to clean the metal shavings from drilling it. I'd just get a boost bolt to replace one of the black ones in the pic. Would be alot easier.
Randy
I wouldnt mess with it. Its just as easy to pick up a boost bolt for about 7-10 bucks.
whats the apps?
