1 - 11 of 11 Posts
so if I have a 1st gen 5.9 and when I purchased it the previous owner put a 2005 turbo on it what can I do to get more boost and have less lag... currently I have an after market fuel pin and have the fuel screws all the way up. It has a 4" exhaust. I have a boost gauge and the most boost I get is 36, but the turbo doesn't get more than 10 psi until I am at 2000rpm or more. On the freeway I run at around 4psi going 60. I was told that the turbo that is on it has a 9 housing.... doesn't that sound right? all I really know about the turbo currently on it is that it came from an 05 and it has a different housing...
Do you have a temp gauge? If not, I would not touch anything till you do get one.
umm why are you not satisfied with the boost. unless you have head studs and a thicker head gasket you dont want to run it more. the turbo you have is a he351 and i dont know why its laggy mine is great
can you tell me more about you boost... maybe I am just being picky.... whats the most boost you can get? Whats the most boost you can sustain? I can hit 36, but then it drops to 32. Really its the lower end that I have a problem with.... on the freeway what are you running boost presure at? From all my reading tonight I wonder if I need to get larger injectors and a different lift pump have you heard anything?
did you weld your blowoff closed?
it's not a blow off valve...it's a wastegate...and there is a hole where the solenoid goes on the CR's...and yes that has to be plugged off somehow
haha, complaining about lag with an HE351 turbo.
your turbo spools better than any other turbo of its size almost guarenteed i hit about 27 pounds and the drop to about 25 my cross over tube i think might have a boost leak inn it though and i run about 5 psi going 60mph and thats all the speeed i do i dont have an over drive tranny
Thats not to shabby i dont think you can get much better low end than with a 9cm housing lol
Ats sells your plug for the solenoid. check them out I think they use them for the coumpound setup they add to factory turbo
My W350 will hit 42 and fall to 39-40 with the wastegate hooked up, but with it adjusted not stock. Cruising down the road at 65 mph it says around 5 ish psi on flat land. Don't really understand the lag question though, mine will hit 40 almost insant once its hit at 5psi.
1 - 11 of 11 Posts
