hello everyboby just put a new radiator in my 3500.5.9-03 and my fan is not going on I can see the fan blades :hyper::hyper:rotating but dosen't engage when the tempeture heats up. Do I need to re-set something?? any help would be greatly appreciate it
Did you make sure there are not any air pockets in the cooling system?
Run the truck for 10 minutes with the radiator cap off.
It shouldnt take long. Just let it idle and it typically works fast.
You might need to do this a few times over a week period to make sure there are not any air pockets.
Be sure to watch the coolant level and add, if needed,
Also check the plug that routes thru the fan shroud from the fan clutch and plugs in on the passenger side. Make sure that you have a good connection.
If it's oveerheating and the fan is not ramping up, start there. It should sound like a plane taking off. Was it working before you replaced the radiator?
