Let me know if any of these are a bad idea. First I am getting a glow shift custom pillar combo. The three guages I selected are boost/vacuum, 100 psi fuel guage, and trans temp guage. The second thing is a cfm+ intake manifold drilled and tapped. and the third is to get a AFE Pro Dry S Stage 2 Type XP Intake System. The reason I am getting an intake manifold before I get the afe is because I dont want to be pulling in more air when it will be restricted by the stock intake manifold.
would a 30 psi work better? those are the only two they have And I am not sure what the pressrue is going to be at normal operation.
30 psi would be just fine. if your over 30 psi on a VP Pump then...wow
over 30 psi.... that would be some extreme throttle response, very CR like
I agree with Turbodiesel..
I'd rate them this way ,,fuel pressure, EGT, tranny. then boost , seeing as your truck is more or less stock, your fuel gauge is right now your most important gauge.
If your gonna keep the stock fuel pump a 15psi gauge is enough, but if your going to upgrade in the future, buy the 30psi now
