Hi everyone, I picked up a new 2020 2500 Bighorn this week and after 500 miles I thought I would check the axle fluid levels. In the past I normally run them about a half inch under the fill hole or sometimes barely under and never had an issue.
I removed the rear fill plug, stuck my index finger down the hole and couldn't touch the fluid. I got a piece of thick wire, made about a 2" bend and stuck that down the hole which just touched the fluid. I added over a half Qt 75-90 and the level now sets about a half inch under. The front also needed a little less then a half Qt.
Anyone else find low axle fluid levels or is that the proper factory fill level?
Prior to my Ram purchase I started drinking the ford koolaid (aluminum body, 10 speed trans) but got my senses together and went with Ram.
Lovin my new truck
Lovin my new truck
