121 - 140 of 140 Posts
Discussion Starter · #121 ·
As like everything with this truck I'm doing more than I intended.
Didn't plan on pulling the brake booster or hvac but here we are
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
Discussion Starter · #122 ·
Had enough time today to pull the transfer case. Hopefully will have enough time to pull the trans tomorrow, if not definitely Saturday
Discussion Starter · #123 ·
Trans is out
Guess it's a good thing I decided to change the rear main seal
New seal installed
And a splash of color on the trans
Super Moderator
You might want to put a new front seal on that trans while it's out also.
Reactions: cutoutcummins
Discussion Starter · #125 ·
Didn't think about that. I'll take a look at it
Super Moderator
A couple dollars now is easier to do then later when it's done and your driving it.
Discussion Starter · #127 ·
Couldn't agree more
Discussion Starter · #128 ·
Is it this
Super Moderator
Did it say diesel when you looked it up? Also look for a seal number on the front of yours.
Discussion Starter · #130 ·
Doesn't say. I'll keep digging. I won't be able to look at it until tomorrow
Super Moderator
There is a front pump bushing in the pump. That is what the converter hub rides in. When they get wear it will cause a leak as well as converter drain back.
Sent from my SM-N975U using Tapatalk
Super Moderator
Guess I've never looked inside.
Discussion Starter · #135 ·
Trans and t case back in. Little bit more work putting it back in than taking it out
2 coats of raptor epoxy primer
And 2 coats of rustoleum gloss black
Reactions: Saintly
I hope you have better luck than I did with the primer...I used the Upol etching primer and it didn't etch or adhere, my Raptor liner is lifting in spots, and it is directly a result of the primer not adhering
Discussion Starter · #137 ·
Hopefully it sticks. I definitely do not want to fix it down the road
Discussion Starter · #139 ·
Cab is finally back on
Reactions: Saintly
Discussion Starter · #140 ·
Got the parts truck in the garage. Time to steal some parts
