81 - 100 of 140 Posts
Discussion Starter · #81 ·
I went back and forth on whether I wanted to spend the money on doing this, and well
Going to bedline the bottom of the cab
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
Reactions: Saintly
Discussion Starter · #83 ·
I did mine with Raptor...this is after a year.
Low pressure, let it splatter...use a regulator at the gun. And prep, prep, prep!
I'm hoping by early next week I'll be able to get the underside done. I just have to fab up the driver's side seat belt "mount" by the door and clean the tunnel off and should be ready to prime then bed line it.
Discussion Starter · #84 ·
Cab floors are finally done. Just need to clean the tunnel up and prime and bed line
Discussion Starter · #85 ·
Well got a little farther than expected today. Mid degreasing
First coat of raptor epoxy primer
And 3rd and final coat
Discussion Starter · #86 ·
2 coats of raptor bed liner
Dragged her out to give the motor one last bath
And got the exhaust mocked up
The underside of that cab looks great!
Are you going to spray the top side of the floor with that bed liner too?
Discussion Starter · #88 ·
Thanks. I haven't decided yet. I'd like to use sound deadening mat and not sure how well it would adhere to the bed liner
Discussion Starter · #89 ·
Slow couple of days. Took way longer than I'd like to admit tweaking the exhaust and figuring out hangers. Installed the new motor mounts
And fabbed up a kdp tab
It'll be about a week before I can finish up the front of the motor. Had to order a tool to install the front main seal
Discussion Starter · #90 ·
Had to buy a special tool just to replace the oil pan
Engine is painted (still need to paint the turbo and intake), new fuel pump, alternator, water pump and turbo oil feed line is in. Replaced the trans filter and gasket.
Was hoping to avoid buying new Trans line's but they needed to be replaced.
Thats the nice cherry picker with the fold up legs, we got that one at my job. You'll like that one!
Reactions: cutoutcummins
Always a good day with new toys!
I'm planning to ditch the coolant-to-trans fluid heat exchanger and just run the big 90 trans cooler and the super-duty cooler.
I'm planning to ditch the coolant-to-trans fluid heat exchanger ......
Me too, having a hell of a time finding 1/2" steel line though. I found some brass compression unions though, I'll probably just bypass it where it crosses over to the passengers side by cutting and joining the line right below the starter motor.
Those are only 24 inches long, also stainless is brittle and crack prone.
Oh, I didn't see that it was annealed. But still, if I was going to replace it I would want like a five or six foot length do it in one shot.
Discussion Starter · #98 ·
I've been thinking about ditching it also but don't want to dump too much into the auto. I still want to find either a nv4500 or 5600. Maybe a zf6 if I can find one for the right price. I didn't want to spend the money on new line's but the hack splice job got to me. Ordered some 8an line and some fittings.
Discussion Starter · #99 ·
Pic of the oil pan installed
New valve cover gaskets
That little rubber brake hose that goes from your engine crossmember down to your axle tube, about how long would you say that hose is?
Also, did you replace that hose with a new one, and if so do you have a part number for it?
