Hi, I have a 94 2500 with 230,000 miles. Ive got a number of issues and the major ones are getting worse. I searched threads for my specific problems but didnt have much luck.
First off, I bought this truck with 220,000 miles and the only mods that I know of are exhaust and k&n filter with no box. It smokes alot under load, more than my previous cummins (same year) so there might be fuel mods. I will number my problems starting with oldest first.
1. leaking oil all over bottom of engine, looks to be coming from passenger side lower front of block. There is a hose that is hooked in the block near there.
2.mileage going from 16 to 14 to 12 and now around 10 in about 2 months and fan clutch is siezed keeping the fan on all the time
3. occasionally when pulling.. the throttle sticks and the truck starts missing but so far has been cured by a full tank of fuel mixed with a quart of oil
4. A large amount of coolant blowing up all over the motor and going through about a gallon per 60 miles and getting worse
5. a large amount of oil that seems to be coming out of the valvle covers, This happened same time as the coolant problems.
Thanks for your help... this is a lifesaving resource!
· Banned
pull head, replace head gasket
hell, i'd pull the motor and rebuild it.
1- turbo oil drain line
2- fix the fan clutch its extra drag on the motor, replace fuel filter and fuel screen
3- lube linkages, check return spring
4- could be the cooler line on the passenger side of the block if thats where the leak is, my 95 did that under load not while idling
5- replace the valve cover gaskets
Hope some of this helps just my opinion on what could be the issues
thanks for the info. Mine only does it on load also but im having trouble locating the leak, ive tried checking it at running temp and rpm but still didn't do it. ill try again, just hoping its not head gasket. thanks again
I hooked up a preasire tester and thats how I found mine. I could drive it and it would never over heat but was loosing water and like I said it was a coolant line on the lower passenger side of the block,I think it was a secondary trans cooler or something but its a little long and round, It only cost a few bucks for a piece of hose
It sounds like your crank case is getting pressurized,could be head gasket,vacuum pump, cracked block.I'd start with a compression test.Good luck
