mp-8 is still nice to have because its adjustable on the fly.... its a pain to always be reprograming.....smarty revo makes the addition of an mp-8 box pretty much useless as rail pressure is already ramped up in the smarty tunes and the "user adjust" menu on the smarty allows you to crank the rail pressure up as high as the stock injection system can handle; recommended only for a temporary time of course =)
You could get more duration out of a TST/Smarty stack and about a year or two ago that was the dominate stack but now people have seemed to moved more to the smarty/pressure box stack since the smarty has evolved a bit.would you benifit from a tst smarty stack rather then a smarty mp8 stack then??
Shift on the fly.but if the smarty does pressure there wouldn't be any need for an mp8?? right?
My Ramifier, the old MP8, does make my juice smoke more...when I want it too. I really helped my mpgs. I got about a 1.5 mpg bump from my pressure box. Now the smarty will smoke a lot on its own so I don't know if you will see a huge difference in smoke with a pressure box but I am sure between some good pressure, which leads to better atomization, and the smarty's legendary timing it would help fuel economy.so you would advise a pressure box? Would it smoke more?
opcorn:
opcorn: Keeping an eye on this one!!
