I just installed my MP-8. Those of you who have installed one already know what a hassel that is. But I found a simple short cut. Of all the places to have a lift bracket :lol3:
The instructions stink. There is no operating instructions at all. I already know where the max power is.
Where is the most economical mode?
After taking it for a ride, set at 100%, I saw the overhead jump up 20 22.6 MPG. (See my thread about the LIe-O-Meter) But it went into ReGen and stayed there while crusing at about 68 MPH for about 30 minutes. The mileage fell way off. 18 MPG at 1200F Degrees EGT I have a gauge)
The only mods I have done so far is an AFE and the MP-8 with the pressure plug in the rail.
This is what you need to install the power plug in the back of the fuel rail. . .
Not with the DPF delete. The higher setting you run the more you will regen if you run it hard. You are producing more soot with the increased Fuel Pressure, as you probably already knew.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Cummins Diesel Forum
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
