1 - 20 of 23 Posts
OK, I just bought a 6" Aussie kit. It says it comes with a 5" thru bed Y pipe. How big of a hole should I cut in the bed? Should it be a snug fit or have plenty of room around it?
Any other tips I may need to know when I install this kit?
Thanks for your advice!!
ILLINOIS NORTHERN VP
6 inch, get a hole saw since it cuts nicely. after you cut the hole work from bottom to top but DO NOT tighten anything until final piece is on
not to far, dont have an exact measurement for ya, but it just misses the bed frame rail underneath the truck, didn't feel like fabin it up
TECH SPECIALIST
How far off the bed does your Y pipe sit?
I'd like to know this too. Mine seem like they sit back a lot farther than everyone else's.
Past IL VP
when I made my kit we 4 inch for the inlet. cut a 4.5 inch hole.... scribed it on the bed drilled one hole and used a sabre saw to get through the bed. then a sawzall to get throught the support bracket below. we didn't have to cut it completely just the edge in order to leave it in for... well suport!
but for a stack 'kit' I'd have to agree w/ Brian.... go oval that should get you about 2-3 inches lower!
pics are required now you know that right>?
Discussion Starter #11
I'm debating putting them on afterwork tommorrow, about how long do stacks take to install?
If you don't alter the kit any, a couple hours should do it.
Dodge | Commins | Forum
Discussion Starter #13
Ok I started installing my stacks today but ran out of daylight. One thing I did notice that I have a question about is the stack mounts. They are L brackets with a bolt (that is attached) + nut, I understand how they work but the front lip on my bed is enclosed (boxed) so I cant to the backside to tighten the nuts.
How do I get around this? Do I need to mount them some other way?
get some self tapping screws then would be my suggestion.
Use the side rails..... ?
Better yet, if your anchored to the floor good enough throw them L brackets in the trash.... Run Clean without them
Discussion Starter #16
The stacks are about a 1/2 inch away from the sides. If I dont use mounts at the top, I figured they might raddle because they side against the front.
I thought about using self tapping screw, but I dont know how they will hold up over time.
Discussion Starter #17
Disregard fellas, I was looking at someones photos on here and now I see how they work, I thought I knew but I guess thats what I get for assuming. Thanks for your help anyway!!!
Discussion Starter #20
I took some pics of where I got tonight.......Im like a kid, I couldnt wait so I set it all in there to see what it looks like LOL...........I will put some more up tommorrow with it all mounted.
1 - 20 of 23 Posts
