You have to watch the cheaper cables, though. Manufacturers will sometimes use aluminum instead of copper.A mix of both. For example, it was cheaper to buy 1 ga 30' jumper cables than to buy 60' of cable, and the quick disconnect ones I have will be shortened to fit the application.
Yep, fully aware of the copper coated aluminum ones. And the copper jumper cables I'm cutting up were on a major sale. The leftover cable and the clamps I can use for something else at some point.You have to watch the cheaper cables, though. Manufacturers will sometimes use aluminum instead of copper.
The tractor is currently stored at our in-town home for now. I'm unsure where it will be stored after it is moved to the property, or how often it might be parked outside overnight, etc. Nonetheless, I'll use the block heater anytime the temperature is below 30*F. Even with synthetic oil, benefits of the block heater have been documented at 20*F temperatures.Lawn mower not wanting to start I the relative cold? I figured your garage was insulated.
Didn't realize you had power out at the property. Guess I should have since you have a well. Outside or inside should not make a difference until you have a heated structure to park it in.The tractor is currently stored at our in-town home for now. I'm unsure where it will be stored after it is moved to the property, or how often it might be parked outside overnight, etc. Nonetheless, I'll use the block heater anytime the temperature is below 30*F. Even with synthetic oil, benefits of the block heater have been documented at 20*F temperatures.
I didn't tell any of mine, either. And most of them don't have block heaters anyway.I guess I'm glad my tractor nor truck have read these documents as they currently start and operate just fine well below 20f.
What? Sold the Powerstroke?It's weird not having anything diesel to plug in right now. Even more odd pulling in the driveway and not seeing it parked up at the barn.
Yep. About 3 weeks ago. Guy contacted me out of the blue and looked at it. Made me a offer I couldn't refuse.What? Sold the Powerstroke?
It's kinda' nice to see this thread back on track again.I installed the BatterMINDer EZ Connector on the same side as the block heater.
