1 - 3 of 3 Posts
So I swapped motors in my ppump 24v this last week, it's all back together minus front clip and I'm trying to test start it before I put it all the way back together.
With both batteries chargesand hooked up, it won't turn over, and even with key in run position fuel pump doesnt prime.
What sensors do I need to have connected?
I don't have the cam sensor, or the alternator hooked up. Is that where my issue is?
I don't want to chase wires for hours and hours if someone can give me a simple explanation for why this is happening.
TIA
Discussion Starter · #2 ·
Forgot a ground. I'm retarded
Cowboy AKA Equality State
Glad you got it solved!
Don't beat yourself up too bad... At least you didn't dump 3 gallons of oil in it with the drain plug out!!!
1 - 3 of 3 Posts
